NickN
#1 Posted : Thursday, October 24, 2024 8:17:44 AM(UTC)
NickN
v27.0.0.85. I have the HEVC codec installed on the machine and have confirmed that it can playback a local file using media player.
I can send h.264 SRT stream to vMix without issues but when I send h.265 I get this error ....
error: failed to configure output type. SRT listener.Decode Thread
I successfully stream h.265 from this same camera source to other end points without problems but for some reason vMix is failing. Any ideas?
BARP
#2 Posted : Thursday, October 24, 2024 3:25:02 PM(UTC)
BARP
What version of Windows are you on? Did you buy the $1 HEVC decoding license from the Windows Store?
https://apps.microsoft.c...7r3t7?hl=en-US&gl=US
NickN
#3 Posted : Friday, October 25, 2024 5:54:02 AM(UTC)
NickN
Yes. Purchased, installed and confirmed HEVC playback via local video file on machine.
Win10 Pro
BARP
#4 Posted : Friday, October 25, 2024 6:15:12 AM(UTC)
BARP
Ok, good. Under Settings -> Performance, do you have more than one option? It's possible, if you have both on-board graphics and a GPU, it could be doing something weird. If so, you may want to go into the nVidia control panel and "pin" vMix to use that GPU exclusively.
NickN
#5 Posted : Friday, October 25, 2024 7:15:11 AM(UTC)
NickN
Only a Tesla T4 option.
I found a NVIDIA menu to "manage 3D settings" that 20+ different features (Antialiasing, CUDA GPUs, Overlay enable, etc) can be specified for vMix. Any idea what setting(s) might need to be tweaked?
Thanks!
BARP
#6 Posted : Friday, October 25, 2024 7:39:16 AM(UTC)
BARP
Since this is related to HEVC decoding. I would start with any kind of encode/decode stuff (like nVenc)
NickN
#7 Posted : Saturday, October 26, 2024 4:32:19 AM(UTC)
NickN
No luck with any of that optimization.
If I untick "Use Hardware Encoder" on the vMix input I do get an image displayed with h.265 but it's garbage and not decoding properly. Looks like it's missing a color channel and pixel information,
nikosman88
#8 Posted : Saturday, October 26, 2024 5:08:35 AM(UTC)
nikosman88
Greece
Thanks!
Is your system local pc or in cloud? And if local you have another gpu for display? Because i see that this kind of GPU doesnt have outputs. Vmix doesnt suggest 2 gpu in same system,so maybe something happens there. Or look maybe for another gpu driver?
BARP
#9 Posted : Saturday, October 26, 2024 6:08:37 AM(UTC)
BARP
Well, garbage we can do something about. If you look in the Stats window in the SRT tab, if you're getting more than 25% packet loss (the default reserve bandwidth setting for SRT), try re-adding the source using a higher latency setting. I did a game where the 4G modems had more than 30% packet loss and bumping the latency up to 5000ms (yes, 5 seconds) totally fixed it.
NickN
#10 Posted : Saturday, October 26, 2024 6:23:59 AM(UTC)
NickN
It's an AWS EC2 g4dn.8xlarge
NickN
#11 Posted : Saturday, October 26, 2024 6:24:59 AM(UTC)
NickN
I will try that.
NickN
#12 Posted : Saturday, October 26, 2024 6:31:19 AM(UTC)
NickN
vMix reporting 0% packet loss. I tried upping the latency anyway. No change.
NickN
#13 Posted : Saturday, October 26, 2024 6:32:35 AM(UTC)
NickN
We tried some different drivers previously with no luck. The different drivers actually totally dorked the NiceDCV screen mirroring.
Guest (4)
