Feature Requests
Custom multichannel audio bus selections for recording/multicorder
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
As it stands now, the only ways to get 4 channels of audio on a recording are:
1) Use buses MA/FG
2) Record more than just 4 channels of audio
3) Use the multicorder or second recorder to record an entirely separate video
Obviously, if all you want is just 4 channels of audio, the last 2 options are a bit ridiculous, given the amount of unnecessary overhead.
And there are plenty of options where you don't want to use M as per common practice or MA doesn't otherwise fit into your workflow for an ancillary recording.
For example, I like to record guests on separate tracks.
When I have just myself and 1 guest, I use Bus D.
When I expand to guests 2 and 3, I'd like to be able to use DE.
I cannot do so with vMix as it currently is, unless I also record every bus (all 16 channels) or record another video file, despite having no additional video to record under my current workflow.
It'd be much simpler if I could just set DE as a 4 channel recording option.
Joined: 8/26/2020(UTC) Posts: 17  Location: Velsen / The Netherlands Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
+1 and for steaming. And to expose the audio selection in the API/shortcuts.
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
+1 incl. streaming. incl. output settings (eg. NDI).
Feature Requests
