WaltG12
#1 Posted : Friday, May 3, 2024 5:42:43 PM(UTC)
WaltG12
As it stands now, the only ways to get 4 channels of audio on a recording are:
1) Use buses MA/FG
2) Record more than just 4 channels of audio
3) Use the multicorder or second recorder to record an entirely separate video
Obviously, if all you want is just 4 channels of audio, the last 2 options are a bit ridiculous, given the amount of unnecessary overhead.
And there are plenty of options where you don't want to use M as per common practice or MA doesn't otherwise fit into your workflow for an ancillary recording.
For example, I like to record guests on separate tracks.
When I have just myself and 1 guest, I use Bus D.
When I expand to guests 2 and 3, I'd like to be able to use DE.
I cannot do so with vMix as it currently is, unless I also record every bus (all 16 channels) or record another video file, despite having no additional video to record under my current workflow.
It'd be much simpler if I could just set DE as a 4 channel recording option.
Mano Bakker
#2 Posted : Thursday, September 19, 2024 6:47:05 PM(UTC)
Mano Bakker
Netherlands
+1
fgolman
#3 Posted : Thursday, October 24, 2024 8:30:10 PM(UTC)
fgolman
+1
nikosman88
#4 Posted : Sunday, October 27, 2024 8:37:25 AM(UTC)
nikosman88
Greece
+1
fgolman
#5 Posted : Wednesday, October 30, 2024 9:56:34 AM(UTC)
fgolman
+1 and for steaming.
And to expose the audio selection in the API/shortcuts.
pm
#6 Posted : Friday, June 20, 2025 5:57:06 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
+1
incl. streaming.
incl. output settings (eg. NDI).
