how to customize filename for split recordings
Joined: 6/22/2020(UTC) Posts: 14  Location: Leipzig Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
we would like to have the recorded files named differently than it does with the default syntax {0} - {1:dd MMMM yyyy - hh-mm-ss tt}. With this syntax it gives us files named like BuKo24_ - 19 Oktober 2024 - 01-45-03 - 00022.mp4 The date,time is always the same for all succeeding recordings showing the date/time when i hit the recording button the first time. We split files automatically every 15minutes and want to know for each single file, when it started to be written.
like : hit record first recorded file : Buko24 -19 Oktober 2024 - 01-45-03 second recorded file: Buko24 -19 Oktober 2024 - 02-00-03 third recorded file: Buko24 -19 Oktober 2024 - 02-15-03
and so on
how can i achieve this by altering the default naming string in vmix settings?
thank you very much for helping
martin
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: mjehnichen  we would like to have the recorded files named differently than it does with the default syntax {0} - {1:dd MMMM yyyy - hh-mm-ss tt}. With this syntax it gives us files named like BuKo24_ - 19 Oktober 2024 - 01-45-03 - 00022.mp4 The date,time is always the same for all succeeding recordings showing the date/time when i hit the recording button the first time. We split files automatically every 15minutes and want to know for each single file, when it started to be written.
and so on
martin AFAIK you can't (wont respond in a way you like) as they all have the same date/time as defined but with a sequential number added But you could write a script ( vMix or external app) to loop through the files (in a folder) , read their GetCreationTime and rename them according to your liking
Some apps they recognize the "series" of files and off an automatic stitching. What might help is a timecode that is integrated in the recording.
