Multiple stream destinations
We have been using vMix for a few years but now have added a second destination that we stream to. When we start the stream, vMix struggles for several minutes to get online. That is, the red indication light at the top of the vmix screen is yellow for up to 10 minutes. If we start stream 1 and then a few seconds later, start stream 2, it works just fine. I don't want to change stream parameters, but would rather have a way to start stream 1 and then 2 with a 2 second delay and have that done with a single click. I can do this manually, but our volunteers struggle with this. Any help would be appreciated.
Joined: 12/27/2012(UTC) Posts: 5,493  Location: Belgium Thanks: 314 times Was thanked: 1019 time(s) in 837 post(s)
Originally Posted by: Plymouth  We have been using vMix for a few years but now have added a second destination that we stream to. When we start the stream, vMix struggles for several minutes to get online. That is, the red indication light at the top of the vmix screen is yellow for up to 10 minutes. If we start stream 1 and then a few seconds later, start stream 2, it works just fine. I don't want to change stream parameters, but would rather have a way to start stream 1 and then 2 with a 2 second delay and have that done with a single click. I can do this manually, but our volunteers struggle with this. Any help would be appreciated. If you want to help your struggeling volunteers use the shortcut functions in a script (called with a shortcut) , with a pauze between each stream start
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Or if you use Companion you can set two "StartStreaming" functions to one button with a 2sec delay.
Originally Posted by: Salvatore  Or if you use Companion you can set two "StartStreaming" functions to one button with a 2sec delay.
That one button shortcut ( function Scriptstart, Value Scriptname) calling the script with the 3 lines of commands is the same without the need for 3rd party app instalation ;-) Code:API.Function("StartStreaming",Value:=0) 'Start stream 1
Sleep(2000) 'wait 2 seconds
API.Function("StartStreaming",Value:=1) 'Start stream 2
