Plymouth
#1 Posted : Tuesday, October 15, 2024 1:26:34 AM(UTC)
Plymouth
We have been using vMix for a few years but now have added a second destination that we stream to. When we start the stream, vMix struggles for several minutes to get online. That is, the red indication light at the top of the vmix screen is yellow for up to 10 minutes. If we start stream 1 and then a few seconds later, start stream 2, it works just fine. I don't want to change stream parameters, but would rather have a way to start stream 1 and then 2 with a 2 second delay and have that done with a single click. I can do this manually, but our volunteers struggle with this. Any help would be appreciated.
#2 Posted : Tuesday, October 15, 2024 1:52:27 AM(UTC)
If you want to help your struggeling volunteers use the shortcut functions in a script (called with a shortcut) , with a pauze between each stream start
Salvatore
#3 Posted : Tuesday, October 15, 2024 1:57:54 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
Or if you use Companion you can set two "StartStreaming" functions to one button with a 2sec delay.
#4 Posted : Tuesday, October 15, 2024 2:07:41 AM(UTC)
That one button shortcut ( function Scriptstart, Value Scriptname) calling the script with the 3 lines of commands is the same without the need for 3rd party app instalation ;-)
Code:
API.Function("StartStreaming",Value:=0)   'Start stream 1
Sleep(2000)                               'wait 2 seconds
API.Function("StartStreaming",Value:=1)   'Start stream 2
