vMix Call
External camera to vmix call
Is there a way to bringing an external camera via vmix call? Example I’m thinking of getting a SDI to USB converter, hook up a broadcast camera via HDSDI port to make a laptop think it’s a webcam to use vmix call. This would give me better quality and less latency in theory.
Yes, you can use a capture device and use it as a webcam in vMixCall. Maybe it's worth for you to take a look into the free NDI tools as they exactly provide the functionality you want, is free and can pick up sources from the network no matter who created them or where they are. All you need is a proper network.
Originally Posted by: mavik  Yes, you can use a capture device and use it as a webcam in vMixCall. Maybe it's worth for you to take a look into the free NDI tools as they exactly provide the functionality you want, is free and can pick up sources from the network no matter who created them or where they are. All you need is a proper network. Hi. Is possible to do something in Android phone? Im using hdmi to usb adapter--> to app usb camera pro and it work for srt/rtmp. But in browser for vmixcall is there any way?
Originally Posted by: nikosman88  Originally Posted by: mavik  Yes, you can use a capture device and use it as a webcam in vMixCall. Maybe it's worth for you to take a look into the free NDI tools as they exactly provide the functionality you want, is free and can pick up sources from the network no matter who created them or where they are. All you need is a proper network. Hi. Is possible to do something in Android phone? Im using hdmi to usb adapter--> to app usb camera pro and it work for srt/rtmp. But in browser for vmixcall is there any way? Te funciono?
If the android device can send SRT there is no need for anything else. vMix can receive SRT directly. Let them know your IP and port and they can connect in caller mode. You have to setup SRT then in listener mode and open a port on your router NAT/PAT it to your vMix machine and maybe you want to use a dDNS service if your ISP changes IP addresses over time.
vMix Call
