is my ISP blocking forums.vmix.com?
Joined: 9/30/2024(UTC) Posts: 3  Location: Oklahoma Thanks: 1 times
I'm not really sure where best to post this, it's such a strange problem... When I try to access forums.vmix.com on my home wifi, be it from my PC, laptop or phone, all I get is a white page. No error page, no loading screens. When I inspect the page, it's literally empty <html><body></body></html> . Just not sure what in the world could be causing this. I'm trying to develop a plugin, and no forum access at home severely complicates things. Anyone else ever experienced this? When I try to search for similar problems, all I can find is discussions on Vmix software functionality (go figure!). I can access my vmix.com account normally, as well as the Table of Contents. But no forums.
Originally Posted by: JobMcKee  I'm not really sure where best to post this, it's such a strange problem... When I try to access forums.vmix.com on my home wifi, be it from my PC, laptop or phone, all I get is a white page. No error page, no loading screens. When I inspect the page, it's literally empty <html><body></body></html> . Just not sure what in the world could be causing this. I'm trying to develop a plugin, and no forum access at home severely complicates things. Anyone else ever experienced this? When I try to search for similar problems, all I can find is discussions on Vmix software functionality (go figure!). I can access my vmix.com account normally, as well as the Table of Contents. But no forums. Tried with another browser ? Checked Modem firewall ? Checked other forums accessibility?
Tried three browsers, and multiple devices, all return a white page when I'm on my home wifi. Figured that indicated it was a higher-level issue. I can successfully access any other websites without problems. Is the modem firewall something I would access within my router configuration? I'll try and disable any sort of blocking at my router level, thanks for the suggestion.
EDIT: even after disabling all firewalls, it makes no difference. What DID make a difference was using a VPN... When I pretend to be in Canada, I can access the forums perfectly fine. Doesn't this indicate that it is something my ISP is doing?
You can also try alternative DNS servers from google or others. Some IPs would be 8.8.8.8 8.8.4.4 1.1.1.1 ....
