JobMcKee
#1 Posted : Monday, October 7, 2024 12:42:59 AM(UTC)
JobMcKee
I'm not really sure where best to post this, it's such a strange problem... When I try to access forums.vmix.com on my home wifi, be it from my PC, laptop or phone, all I get is a white page. No error page, no loading screens. When I inspect the page, it's literally empty <html><body></body></html> . Just not sure what in the world could be causing this. I'm trying to develop a plugin, and no forum access at home severely complicates things.
Anyone else ever experienced this? When I try to search for similar problems, all I can find is discussions on Vmix software functionality (go figure!).
I can access my vmix.com account normally, as well as the Table of Contents. But no forums.
#2 Posted : Monday, October 7, 2024 12:48:47 AM(UTC)
Tried with another browser ?
Checked Modem firewall ?
Checked other forums accessibility?
JobMcKee
#3 Posted : Monday, October 7, 2024 1:12:06 AM(UTC)
JobMcKee
Tried three browsers, and multiple devices, all return a white page when I'm on my home wifi. Figured that indicated it was a higher-level issue. I can successfully access any other websites without problems. Is the modem firewall something I would access within my router configuration? I'll try and disable any sort of blocking at my router level, thanks for the suggestion.
EDIT: even after disabling all firewalls, it makes no difference. What DID make a difference was using a VPN... When I pretend to be in Canada, I can access the forums perfectly fine. Doesn't this indicate that it is something my ISP is doing?
mavik
#4 Posted : Monday, October 7, 2024 6:21:44 PM(UTC)
mavik
You can also try alternative DNS servers from google or others. Some IPs would be
8.8.8.8
8.8.4.4
1.1.1.1
