Petrov
#1 Posted : Friday, September 27, 2024 11:07:13 PM(UTC)
Petrov
Romania
Hello!
I want to create a backup chain to ingest materials, and for this project, I want to use vMix. However, the problem is that I need an XDCAM 422 format for recording, but unfortunately, I can't find it in the recording settings.
To briefly explain the chain: Video source -> PC capture card -> shared folder -> server destination
Is there a way I can set this manually or force it?
Thank you.
WaltG12
#2 Posted : Saturday, September 28, 2024 7:06:19 AM(UTC)
WaltG12
Can you fake it/duplicate it with FFMPEG?
nikosman88
#3 Posted : Saturday, September 28, 2024 10:07:35 AM(UTC)
nikosman88
Greece
Hello. Another one feature request that is waiting it`s order to be implemented https://forums.vmix.com/...HD422-codec-in-RECORDING
Peter1000
#4 Posted : Friday, October 4, 2024 5:39:10 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
You can add this option manually. However, this should be done by an experienced PC user. Unfortunately, this has to be repeated after every vMix update.
Description here
