How to setup XDCAM 422 in recording
Joined: 7/26/2024(UTC) Posts: 2   Location: Bucharest
Hello! I want to create a backup chain to ingest materials, and for this project, I want to use vMix. However, the problem is that I need an XDCAM 422 format for recording, but unfortunately, I can't find it in the recording settings.
To briefly explain the chain: Video source -> PC capture card -> shared folder -> server destination
Is there a way I can set this manually or force it?
Thank you.
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Can you fake it/duplicate it with FFMPEG?
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
You can add this option manually. However, this should be done by an experienced PC user. Unfortunately, this has to be repeated after every vMix update. Description here
