vMix Zoom Client – Update Requirements and Language Interpretation Tips
Joined: 7/10/2020(UTC) Posts: 35   Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
I want to share a strange behavior of the vMix Zoom Plugin. This isn’t exactly a bug, but more of a tip for users who might be wondering what's wrong with the plugin.
Client Update Requirement
Some Zoom account administrators require clients to have the latest or a specific version of Zoom. In Zoom settings (global or user), there is an option to “Require users to update the client.”
As of July 2024, if you set Windows requirements above version 6.0.11 (39959), such as 6.1.x, vMix cannot connect to Zoom meetings. It will attempt to connect but will eventually stop.
I'm not sure if vMix can solve this problem by bypassing this requirement, but users need to be aware and cautious.
I've noticed that if vMix connects to a meeting with interpretation enabled, to get the languages into vMix Audio options, you need to start the interpretation first and then join with the vMix Zoom Plugin. Additionally, if you change the language set during the event, the vMix Zoom Plugin can’t detect this change.
I’m unsure if this can be fixed with an update daemon, but in real events, we first connect vMix to Zoom and then wait for interpreters to join the meeting.
The good news is that this issue isn’t affected by closing and starting interpretation again. Therefore, my tip is to start a "fake" interpretation at the beginning and then add the real interpreters when they join the event.
Hope this helps!
 2 users thanked tsioukas for this useful post.
Where does one get this vMix Zoom Plugin? Is there a plug in place?
EDITED TO SAY: Nevermind, found it but it says vMix 27 or higher. We're on 25.
Joined: 6/29/2022(UTC) Posts: 2   Location: MG Thanks: 1 times
Not a solution, but I want to share the exact same thing. The scenario:
Host: Zoom Meeting Client 6.2.3 VMix: 27.0.0.84 Win 10 22H2 Interpreters: Zoom client Windows 6.2.0 Port to english Zoom client Windows 6.2.3 Port to english
Thanks!
Joined: 2/7/2024(UTC) Posts: 193  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
The vMix Zoom Plugin is based on the standard Zoom SDK, which always runs behind in version compared to the actual Zoom application. If you require a minimum version to join the Zoom, then yes...there's a possibility the vMix Zoom plugin won't be able to join your meeting since it is never as up to date as Zoom itself. You would need to remove the requirement or reduce the setting so that the minimum version acceptable is older than the version of Zoom SDK that the vMix Zoom plugin is built on.
