Joined: 8/3/2020(UTC) Posts: 25  Location: Madison Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I'm having an issue with cropping multiple layers in a single input. Example: I have one input that's a background plate and another input that's my keyed green screen camera. I create a blank input and stack the two other inputs as separate layers, so that the background plate appears behind my keyed footage. If I crop the master layer, it only crops the camera input layer. But, I would expect it to crop the background layer as well. To test this phenomenon even further, I created another blank input of the stacked layer input. Still, the crop effect only affects my camera layer.
I have done this in earlier versions of vMix without a problem, but this cropping behavior in the latest v27 of vMix (27.0.0.81) seems new and weird to me.
Anyone else notice this phenomenon?
Any insight is greatly appreciated.
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
Joined: 12/8/2022(UTC) Posts: 164  Thanks: 49 times Was thanked: 3 time(s) in 3 post(s)
Just stumbled on this thread while trying and failing to crop a greenscreen input with two layers, when in a layer in another input to create a sidebyside box layout. The Mix input worked but seemed a bit overkill for this. Looked once more on the greenscreen input and found "flatten layers". Ticked it and booom now I can crop the input when in a layer! Hopefully this can help others who run into this. /T
 1 user thanked TL68 for this useful post.
Appreciate you, TL68. Just the info I needed.
