jermanprod
#1 Posted : Wednesday, September 4, 2024 6:40:39 AM(UTC)
jermanprod
I'm having an issue with cropping multiple layers in a single input.
Example: I have one input that's a background plate and another input that's my keyed green screen camera.
I create a blank input and stack the two other inputs as separate layers, so that the background plate appears behind my keyed footage.
If I crop the master layer, it only crops the camera input layer. But, I would expect it to crop the background layer as well.
To test this phenomenon even further, I created another blank input of the stacked layer input. Still, the crop effect only affects my camera layer.
I have done this in earlier versions of vMix without a problem, but this cropping behavior in the latest v27 of vMix (27.0.0.81) seems new and weird to me.
Anyone else notice this phenomenon?
Any insight is greatly appreciated.
sinc747
#2 Posted : Friday, September 13, 2024 6:05:17 AM(UTC)
sinc747
vMix can do what you want using the Mix Input.
Here's Tim teaching about the Mix Input:
?si=9cEC2h215bUvuWHB
Here's me showing how to crop using the Mix Input: https://www.youtube.com/...HRZuCxNKoUptc&t=1268
Best wishes!
- Tom
TL68
#3 Posted : Thursday, February 26, 2026 10:57:00 PM(UTC)
TL68
Sweden
Just stumbled on this thread while trying and failing to crop a greenscreen input with two layers, when in a layer in another input to create a sidebyside box layout.
The Mix input worked but seemed a bit overkill for this. Looked once more on the greenscreen input and found "flatten layers". Ticked it and booom now I can crop the input when in a layer!
Hopefully this can help others who run into this. /T
Guest (4)
