sivertb
#1 Posted : Saturday, August 31, 2024 12:04:45 AM(UTC)
sivertb
Norway
Is it possible to use the API or scripting or something to control vMix Call?
Would be nice to be able for our journalists to add a vMix Call input and retrieve the URL and password, as well as delete the input afterwards. That way they can fix everything themselves during production, when they need to have a guest on.
Thanks!
Sivert, P4 Radio
mavik
#2 Posted : Monday, September 2, 2024 7:21:17 PM(UTC)
mavik
May you can create an input with 8 calls in different layers and a holding slide in 9th layer. Then connect one of the calls and move it to layer 10 (on top of all). Once done move back to original layer.
