knbPixels
#1 Posted : Tuesday, August 20, 2024 11:32:35 PM(UTC)
knbPixels
Our show operates on eastern timezone, trying to incorporate a clock into the show and show it on air. It cannot rely on the local computer clock at all, because we have operators in other time zones as well, and we are trying to accomplish this without using different time offsets and therefore different show file versions.
Anyone know of a way to pull the time of day from perhaps a website, as a data feed into a title, or something like that? We don't need to display seconds, just the hour and minute.
#2 Posted : Tuesday, August 20, 2024 11:48:59 PM(UTC)
Maybe this might help (google help ;-) ) in a script to display ( sorry Retrieve) eastern time from any computer anywhere
Code:
Dim eastern As DateTime = TimeZoneInfo.ConvertTimeBySystemTimeZoneId(DateTime.UtcNow, "Eastern Standard Time")
knbPixels
#3 Posted : Tuesday, August 20, 2024 11:55:07 PM(UTC)
knbPixels
Maybe this might help (google help ;-) ) in a script to display eastern time from any computer anywhere
Code:
I know nothing about scripting but I'll give it a shot, thanks!
#4 Posted : Wednesday, August 21, 2024 12:03:56 AM(UTC)
Code:
to actually get that time on an input you will have to use a title and put the data from the script in the title and layer it on the input
"Scripting for dummies" Post in the forum should help you along
#5 Posted : Wednesday, August 21, 2024 12:16:15 AM(UTC)
Here you go
Code:
Do while True
  API.Function("SetText",Input:="Text Middle Centre Left Right Sharp.gtzip",SelectedName:="Message.Text",Value:=eastern.ToString("HH:mm"))
  Sleep(250)
Loop
'where "Text Middle Centre Left Right Sharp.gtzip" is the name of a standard vMix title input
Copy code into a script, save and run it
knbPixels on 8/21/2024(UTC)
knbPixels
#6 Posted : Wednesday, August 21, 2024 12:17:31 AM(UTC)
knbPixels
Here you go
Code:
Do while True
  Sleep(250)
Loop
Thanks I'll try that!
knbPixels
#7 Posted : Wednesday, August 21, 2024 6:43:10 AM(UTC)
knbPixels
Here you go
Code:
Do while True
  Sleep(250)
Loop
Made an input from a standard vMix title input, left it as it comes standard....then I added the script and ran it, but I get nothing happening in the input I created. I also made sure the input name matches that same name of the title I selected, and nothing happens.
#8 Posted : Wednesday, August 21, 2024 6:50:03 AM(UTC)
You say a standard vMix title , not all titles contain a fieldname that is called "Message.Text" , maybe check that
or maybe a screenshot of the title editor and of the script
knbPixels
#9 Posted : Wednesday, August 21, 2024 6:57:44 AM(UTC)
knbPixels
I actually just used the standard title that you chose as an example
image (14).png (33kb) downloaded 2 time(s). image (15).png (32kb) downloaded 1 time(s).
#10 Posted : Wednesday, August 21, 2024 7:06:39 AM(UTC)
Strange as i can asure you that it works here
add: console.writeline(eastern) between the line Dim.. and API... and see what it says in the console when you run the script (= keeping the settings-script window open/ the black part )
knbPixels
#11 Posted : Wednesday, August 21, 2024 7:08:28 AM(UTC)
knbPixels
The console returns the date and time in Eastern TZ
knbPixels
#12 Posted : Wednesday, August 21, 2024 7:11:21 AM(UTC)
knbPixels
When I start a new project file I can get the time to appear in the input, although it's in 24 hour format. Maybe I have an errant input that it's affecting in my main file, let me check
knbPixels
#13 Posted : Wednesday, August 21, 2024 7:15:10 AM(UTC)
knbPixels
Ok yeah, I already had a title created that was called that same title name and it was being affected instead of the new one....got that sorted out. It's in 24 hour format
#14 Posted : Wednesday, August 21, 2024 7:18:52 AM(UTC)
see change at end for AM/PM time display
API.Function("SetText",Input:="Text Middle Centre Left Right Sharp.gtzip",SelectedName:="Message.Text",Value:=eastern.ToString("HH:mm tt"))
knbPixels
#15 Posted : Wednesday, August 21, 2024 7:21:04 AM(UTC)
knbPixels
Got it, thanks! fully functional now! you rock!
