Pulling time of day into an input?
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Our show operates on eastern timezone, trying to incorporate a clock into the show and show it on air. It cannot rely on the local computer clock at all, because we have operators in other time zones as well, and we are trying to accomplish this without using different time offsets and therefore different show file versions.
Anyone know of a way to pull the time of day from perhaps a website, as a data feed into a title, or something like that? We don't need to display seconds, just the hour and minute.
Originally Posted by: knbPixels  Our show operates on eastern timezone, trying to incorporate a clock into the show and show it on air. It cannot rely on the local computer clock at all, because we have operators in other time zones as well, and we are trying to accomplish this without using different time offsets and therefore different show file versions.
Anyone know of a way to pull the time of day from perhaps a website, as a data feed into a title, or something like that? We don't need to display seconds, just the hour and minute. Maybe this might help (google help ;-) ) in a script to display ( sorry Retrieve) eastern time from any computer anywhere Code:Dim eastern As DateTime = TimeZoneInfo.ConvertTimeBySystemTimeZoneId(DateTime.UtcNow, "Eastern Standard Time")
Originally Posted by: doggy  Originally Posted by: knbPixels  Our show operates on eastern timezone, trying to incorporate a clock into the show and show it on air. It cannot rely on the local computer clock at all, because we have operators in other time zones as well, and we are trying to accomplish this without using different time offsets and therefore different show file versions.
Anyone know of a way to pull the time of day from perhaps a website, as a data feed into a title, or something like that? We don't need to display seconds, just the hour and minute. Maybe this might help (google help ;-) ) in a script to display eastern time from any computer anywhere Code:Dim eastern As DateTime = TimeZoneInfo.ConvertTimeBySystemTimeZoneId(DateTime.UtcNow, "Eastern Standard Time")
I know nothing about scripting but I'll give it a shot, thanks!
Originally Posted by: knbPixels  Originally Posted by: doggy  Originally Posted by: knbPixels  Our show operates on eastern timezone, trying to incorporate a clock into the show and show it on air. It cannot rely on the local computer clock at all, because we have operators in other time zones as well, and we are trying to accomplish this without using different time offsets and therefore different show file versions.
I know nothing about scripting but I'll give it a shot, thanks! to actually get that time on an input you will have to use a title and put the data from the script in the title and layer it on the input "Scripting for dummies" Post in the forum should help you along
Here you go Code:
Do while True
API.Function("SetText",Input:="Text Middle Centre Left Right Sharp.gtzip",SelectedName:="Message.Text",Value:=eastern.ToString("HH:mm"))
Sleep(250)
Loop
'where "Text Middle Centre Left Right Sharp.gtzip" is the name of a standard vMix title input
Copy code into a script, save and run it
Originally Posted by: doggy  Here you go Code:
Do while True
Sleep(250)
Loop
Copy code into a script, save and run it Thanks I'll try that!
Do while True
Sleep(250)
Loop
Copy code into a script, save and run it Made an input from a standard vMix title input, left it as it comes standard....then I added the script and ran it, but I get nothing happening in the input I created. I also made sure the input name matches that same name of the title I selected, and nothing happens.
You say a standard vMix title , not all titles contain a fieldname that is called "Message.Text" , maybe check that or maybe a screenshot of the title editor and of the script
You say a standard vMix title , not all titles contain a fieldname that is called "Message.Text" , maybe check that or maybe a screenshot of the title editor and of the script I actually just used the standard title that you chose as an example  image (14).png (33kb) downloaded 2 time(s). image (15).png (32kb) downloaded 1 time(s).
Originally Posted by: knbPixels  I actually just used the standard title that you chose as an example
Strange as i can asure you that it works here add: console.writeline(eastern) between the line Dim.. and API... and see what it says in the console when you run the script (= keeping the settings-script window open/ the black part )
Originally Posted by: doggy  Originally Posted by: knbPixels  I actually just used the standard title that you chose as an example
Strange as i can asure you that it works here add: console.writeline(eastern) between the line Dim.. and API... and see what it says in the console when you run the script (= keeping the settings-script window open/ the black part ) The console returns the date and time in Eastern TZ
Strange as i can asure you that it works here add: console.writeline(eastern) between the line Dim.. and API... and see what it says in the console when you run the script (= keeping the settings-script window open/ the black part ) When I start a new project file I can get the time to appear in the input, although it's in 24 hour format. Maybe I have an errant input that it's affecting in my main file, let me check
Ok yeah, I already had a title created that was called that same title name and it was being affected instead of the new one....got that sorted out. It's in 24 hour format
Originally Posted by: knbPixels  Ok yeah, I already had a title created that was called that same title name and it was being affected instead of the new one....got that sorted out. It's in 24 hour format see change at end for AM/PM time display API.Function("SetText",Input:="Text Middle Centre Left Right Sharp.gtzip",SelectedName:="Message.Text",Value:=eastern.ToString("HH:mm tt"))
Originally Posted by: doggy  Originally Posted by: knbPixels  Ok yeah, I already had a title created that was called that same title name and it was being affected instead of the new one....got that sorted out. It's in 24 hour format see change at end for AM/PM time display API.Function("SetText",Input:="Text Middle Centre Left Right Sharp.gtzip",SelectedName:="Message.Text",Value:=eastern.ToString("HH:mm tt")) Got it, thanks! fully functional now! you rock!
