mihait93
#1 Posted : Tuesday, July 2, 2024 7:32:57 PM(UTC)
mihait93
Romania
Hello! I sometimes encountered problems with the clips loaded in vmix, when I play them through Companion, they get stuck at the first frame and don't play. I mention that the files are loaded from Google Drive, and the Drive is mapped on the PC. Have you encountered such problems before? How did you solve it?
miro_lee
#2 Posted : Tuesday, July 2, 2024 11:48:57 PM(UTC)
miro_lee
Italy
Since the files are loaded from Google Drive, there could be network latency or issues with the drive mapping. Try copying the files to a local drive and see if the problem persists, maybe you can check if the mapped Google Drive has proper access permissions too.
