Hello! I sometimes encountered problems with the clips loaded in vmix, when I play them through Companion, they get stuck at the first frame and don't play. I mention that the files are loaded from Google Drive, and the Drive is mapped on the PC. Have you encountered such problems before? How did you solve it?
Joined: 7/16/2021(UTC) Posts: 24  Location: Legnano Thanks: 2 times
Originally Posted by: mihait93  Hello! I sometimes encountered problems with the clips loaded in vmix, when I play them through Companion, they get stuck at the first frame and don't play. I mention that the files are loaded from Google Drive, and the Drive is mapped on the PC. Have you encountered such problems before? How did you solve it? Since the files are loaded from Google Drive, there could be network latency or issues with the drive mapping. Try copying the files to a local drive and see if the problem persists, maybe you can check if the mapped Google Drive has proper access permissions too.
