Sending http requests to Companion 3.x in script
Hi Folks
Anyone have some sample code to send an Http Post request to press a button in Companion 3.x from a vmix script.
Joined: 12/27/2012(UTC) Posts: 5,449  Location: Belgium Thanks: 311 times Was thanked: 1008 time(s) in 830 post(s)
Thanks Could be mistaken but am guessing that "button" performs an action/function for vMix so am wondering why not do this strait from the script ? Btw have you searched the forum for Http request or google for vb.net Httprequest
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Originally Posted by: doggy  Originally Posted by: Mollertom  Hi Folks Anyone have some sample code to send an Http Post request to press a button in Companion 3.x from a vmix script. Thanks Could be mistaken but am guessing that "button" performs an action/function for vMix so am wondering why not do this strait from the script ? Btw have you searched the forum for Http request or google for vb.net Httprequest Button presses, and other stuff, in Companion can do many things that cannot be done in vMix. I think (doggy might correct me on this) that generally TCP would be a more efficient method than HTTP requests. So that is what I am using. I posted an example in https://forums.vmix.com/...-for-Dummies#post114636. Please feel free to modify it for Button presses. Cheers!
Thank you for your help. I did need to press a button in Companion to control an ATEM. This worked well when I modified it for a button press which is my immediate need, but I could not get a custom variable to change. Do you see anything I could be doing wrong. I commented out the loop to simplify it even further. The variable exists as I copied its name.
Thanks again for your help and posting that simple bit of code is super helpful.
' Prepare for TCP Dim tcpCompanionIP as string = "127.0.0.1" Dim tcpCompanionPort as integer = "16759" Dim client As New System.Net.Sockets.TcpClient(tcpCompanionIP, tcpCompanionPort) Dim stream As System.Net.Sockets.NetworkStream = client.GetStream()
' Define variables Dim content As String = "Test_TCP" Dim numberOfTimes as Integer = 4
' Loop a number of times ' For aNumber as Integer = 1 to numberOfTimes Dim customVariableName As String = "$(internal:Cam_Transition) " Dim companionCommand as String = "CUSTOM-VARIABLE " & customVariableName & " SET-VALUE " & content Dim data As [Byte]() = System.Text.Encoding.ASCII.GetBytes(companionCommand & Environment.NewLine) stream.Write(data, 0, data.Length) ' Next
' Close TCP stream.Close() client.Close()
try instead with Dim customVariableName As String = "Cam_Transition"
/richard
 1 user thanked richardgatarski for this useful post.
Thats what I needed thank you.
