Mollertom
#1 Posted : Friday, June 28, 2024 2:23:41 AM(UTC)
Mollertom
Canada
Hi Folks
Anyone have some sample code to send an Http Post request to press a button in Companion 3.x from a vmix script.
#2 Posted : Friday, June 28, 2024 3:39:00 AM(UTC)
Originally Posted by: Mollertom Go to Quoted Post
Hi Folks
Could be mistaken but am guessing that "button" performs an action/function for vMix so am wondering why not do this strait from the script ?
Btw have you searched the forum for Http request or google for vb.net Httprequest
richardgatarski
#3 Posted : Friday, June 28, 2024 8:45:38 AM(UTC)
richardgatarski
Hi Folks
Button presses, and other stuff, in Companion can do many things that cannot be done in vMix.
I think (doggy might correct me on this) that generally TCP would be a more efficient method than HTTP requests. So that is what I am using.
I posted an example in https://forums.vmix.com/...-for-Dummies#post114636. Please feel free to modify it for Button presses.
Cheers!
Mollertom
#4 Posted : Friday, June 28, 2024 9:23:23 PM(UTC)
Mollertom
Canada
Thank you for your help. I did need to press a button in Companion to control an ATEM. This worked well when I modified it for a button press which is my immediate need, but I could not get a custom variable to change. Do you see anything I could be doing wrong. I commented out the loop to simplify it even further. The variable exists as I copied its name.
Thanks again for your help and posting that simple bit of code is super helpful.
' Prepare for TCP
Dim tcpCompanionIP as string = "127.0.0.1"
Dim tcpCompanionPort as integer = "16759"
Dim client As New System.Net.Sockets.TcpClient(tcpCompanionIP, tcpCompanionPort)
Dim stream As System.Net.Sockets.NetworkStream = client.GetStream()
' Define variables
Dim content As String = "Test_TCP"
Dim numberOfTimes as Integer = 4
' Loop a number of times
' For aNumber as Integer = 1 to numberOfTimes
Dim customVariableName As String = "$(internal:Cam_Transition) "
Dim companionCommand as String = "CUSTOM-VARIABLE " & customVariableName & " SET-VALUE " & content
Dim data As [Byte]() = System.Text.Encoding.ASCII.GetBytes(companionCommand & Environment.NewLine)
stream.Write(data, 0, data.Length)
' Next
' Close TCP
stream.Close()
client.Close()
richardgatarski
#5 Posted : Saturday, June 29, 2024 6:05:35 AM(UTC)
richardgatarski
try instead with
Dim customVariableName As String = "Cam_Transition"
/richard
Mollertom on 6/30/2024(UTC)
Mollertom
#6 Posted : Sunday, June 30, 2024 10:08:40 AM(UTC)
Mollertom
Canada
Thats what I needed thank you.
