Panasonic AG-CX350 over NDI PTZ
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
Hi Community, In vMix I tried to control the Panasonic AG-CX350 with the NDI plugin be controlled from the input PTZ control (Zoom and Focus) but I can't connect to it with the provided selections. If I use the NDI Studio Monitor Controller it's directly at my hands and works as expected. It would be nice to get the same in vMix somehow to be used in virtual inputs with different zoom or focal points.
Has anybody got it connected with vMix to be able to control it.
Or more a feature request to add NDI as a control protocol
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
What Device Type are you selecting on the PTZ tab of that input?
I'm guessing Sony VISCA Over IP might be your best bet.
- Tom
I tried but I couldn't get it to work over visca
Joined: 3/21/2022(UTC) Posts: 52  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: mavik  Hi Community, In vMix I tried to control the Panasonic AG-CX350 with the NDI plugin be controlled from the input PTZ control (Zoom and Focus) but I can't connect to it with the provided selections. If I use the NDI Studio Monitor Controller it's directly at my hands and works as expected. It would be nice to get the same in vMix somehow to be used in virtual inputs with different zoom or focal points.
Or more a feature request to add NDI as a control protocol Hi, I had the same issue with a KiloView Encoder that translates NDI PTZ commands to serial commands for older PTZs. The encoder would thus convert a classic PTZ with serial and SDI to a "NDI PTZ". There I had the same problem. Digging in the vMix forums I found this answer from Martin: https://forums.vmix.com/...1039-PTZ-control-via-NDII have to agree with him here: If the system does not allow to implement PTZ presets, there is little us for it. Would be interesting if this had changed in newer NDI versions. I know that in the NDI studio Monitor PTZ controller one can save and recall snapshots. Over at the NDI forum there is some good background to it: https://forum.vizrt.com/...-and-ptz-control.244521/Best regards, Christian
