mavik
#1 Posted : Thursday, May 23, 2024 12:42:12 AM(UTC)
mavik
Hi Community,
In vMix I tried to control the Panasonic AG-CX350 with the NDI plugin be controlled from the input PTZ control (Zoom and Focus) but I can't connect to it with the provided selections. If I use the NDI Studio Monitor Controller it's directly at my hands and works as expected. It would be nice to get the same in vMix somehow to be used in virtual inputs with different zoom or focal points.
Has anybody got it connected with vMix to be able to control it.
Or more a feature request to add NDI as a control protocol
sinc747
#2 Posted : Saturday, June 1, 2024 3:20:07 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
What Device Type are you selecting on the PTZ tab of that input?
I'm guessing Sony VISCA Over IP might be your best bet.
- Tom
mavik
#3 Posted : Monday, June 17, 2024 11:43:22 PM(UTC)
mavik
I tried but I couldn't get it to work over visca
ckvideo
#4 Posted : Saturday, June 22, 2024 6:55:22 PM(UTC)
ckvideo
Germany
Originally Posted by: mavik Go to Quoted Post
Hi Community,
I had the same issue with a KiloView Encoder that translates NDI PTZ commands to serial commands for older PTZs. The encoder would thus convert a classic PTZ with serial and SDI to a "NDI PTZ".
There I had the same problem.
Digging in the vMix forums I found this answer from Martin:
https://forums.vmix.com/...1039-PTZ-control-via-NDI
I have to agree with him here: If the system does not allow to implement PTZ presets, there is little us for it.
Would be interesting if this had changed in newer NDI versions. I know that in the NDI studio Monitor PTZ controller one can save and recall snapshots.
Over at the NDI forum there is some good background to it: https://forum.vizrt.com/...-and-ptz-control.244521/
Best regards,
Christian
