Issue with Key/Fill on Zoom Shared Screen input
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
I have a participant that will be sharing screen from a mobile phone for a demo. I want to mask their screen share to give it rounded corners. If I use the mask I created on a Zoom camera input, it works perfectly. If I use the mask on the live screen share from the phone, the mask gets compressed horizontally by a huge factor. I'm guessing it has something to do with the screen share not being 1920x1080. If I take a snapshot of that live share and mask it, it works fine. I tried to create a new input and put that live sharing input on it as a layer, and then mask it, but that doesn't work because the masking only effects the actual input (layer 0), and not any of the other layers. How can I solve this issue? Attaching pic of the phone share snap that does work, alongside the live input which doesn't work.  image (8).png (408kb) downloaded 4 time(s).
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
Have you tried sending it to a mix input and masking the mix input?
Originally Posted by: dmwkr  Have you tried sending it to a mix input and masking the mix input? That seems to be working, so a decent work around at least...thanks for the idea!
