 Joined: 10/31/2022(UTC) Posts: 14   Location: Camerino Was thanked: 3 time(s) in 2 post(s)
                Hi everyone, i have a RGBLINK mini that i use via USB with VMIX.. everything worked fine until a couple of months ago
  i use it on 3 computers.. on my main station everything is still working ok.. on a notebook and on a secondary station i have the following problem...
  i connect the rgblink mini via usb 3.. i use it as an CAMERA INPUT in vmix.. everything is working good at the beginning.. but after a couple of minutes (randomly) the video freezes.. if i use the tbar on the rgblink mini it will not work on vmix, i still see the video freezed.. the strange thing is that the audio still works fine, only the video is blocked
  if i unplug.. and replug the rgblink it restart working fine for some minutes until it freezes again..
  any of you use this device? are you getting problems?
  thank you very much
                Hello, I have the same problem, I thought it was a firmware problem, but it keeps happening. Maybe you could solve it?
