INTERLACED AND PROGRESSIVE AT THE SAME TIME.
I have to broadcast live in interlaced and progressive at the same time. Can VMIX do this?
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Yes, no problem. Set the project to 1080/50p (or 60p) Then set one of the external outputs to 50i (or 60i) So you can stream progressively and output the interlaced format via SDI.
Thanks for the reply. Yes, as you say, I have done it before, but what I want is to send to two different addresses, one in interlaced and the other in progressive BUT without using any external device or the external function of VMIX.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
You could set up vMix to output your 60p or 50p progressive stream, and enable NDI output. Run a second instance of vMix, and set the master frame rate to 60i or 50i, input the NDI feed and output a stream.
In order to run multiple instances of vMix on one computer, go to Settings->Options, and check the box that says "enable multiple instances"
Joined: 8/14/2023(UTC) Posts: 18  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
vMix can't do interlaced stream!
That's what I was afraid of: you can't stream interlaced without resorting to external hardware.
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: jaialai  That's what I was afraid of: you can't stream interlaced without resorting to external hardware. https://www.vmix.com/hel...ndex.htm?Interlaced.htmlThat mentions interlaced output but not necessarily as a stream output though it's probably supported.
