jaialai
#1 Posted : Thursday, May 9, 2024 4:37:05 PM(UTC)
jaialai
I have to broadcast live in interlaced and progressive at the same time. Can VMIX do this?
Peter1000
#2 Posted : Thursday, May 9, 2024 9:43:10 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
Yes, no problem. Set the project to 1080/50p (or 60p)
Then set one of the external outputs to 50i (or 60i)
So you can stream progressively and output the interlaced format via SDI.
jaialai
#3 Posted : Friday, May 10, 2024 4:34:13 AM(UTC)
jaialai
Thanks for the reply. Yes, as you say, I have done it before, but what I want is to send to two different addresses, one in interlaced and the other in progressive BUT without using any external device or the external function of VMIX.
kross
#4 Posted : Friday, May 10, 2024 12:44:06 PM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
You could set up vMix to output your 60p or 50p progressive stream, and enable NDI output. Run a second instance of vMix, and set the master frame rate to 60i or 50i, input the NDI feed and output a stream.
In order to run multiple instances of vMix on one computer, go to Settings->Options, and check the box that says "enable multiple instances"
mnmilos
#5 Posted : Friday, May 10, 2024 7:02:35 PM(UTC)
mnmilos
Serbia
vMix can't do interlaced stream!
jaialai
#6 Posted : Sunday, May 12, 2024 5:50:58 AM(UTC)
jaialai
That's what I was afraid of: you can't stream interlaced without resorting to external hardware.
Roy Sinclair
#7 Posted : Tuesday, May 14, 2024 8:14:32 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
https://www.vmix.com/hel...ndex.htm?Interlaced.html
That mentions interlaced output but not necessarily as a stream output though it's probably supported.
