Joined: 2/27/2024(UTC) Posts: 8  Location: Missouri Thanks: 2 times
Sometimes the dropdown box beside the full screen feature will not open to allow different inputs. When it does it works fine but I can't always rely on it opening for me to change inputs!
Any suggestion. I have the latest vmix software update and recently got a Dell computer with the specs from the Vmix website..so can you tell me why it is acting up?
Mike
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
I just realise that I am having the same issue, maybe it was there in earlier versions, but since I do not use that feature often, I may have missed it....I don't have a fix, but the last time I had any issue with vMix functions not responding, I just restart vMix, and things work again, ...I know that is not a good thing when on a job, but sometimes you have to do what you have to do......
Vmix is great piece of software.Once you follow the load that your hw can support everything ok but... BUT... Windows is a crap piece of software.99% will work ok but not always. That`s why sometimes happen weird things. This is my opinion after almost 3 years of vmix as my video mixer Originally Posted by: Luis70  I just realise that I am having the same issue, maybe it was there in earlier versions, but since I do not use that feature often, I may have missed it....I don't have a fix, but the last time I had any issue with vMix functions not responding, I just restart vMix, and things work again, ...I know that is not a good thing when on a job, but sometimes you have to do what you have to do...... exactly. Also these "weird-sudden" problems can be solved with a pc restart.. Until the next time..that`s why if you have any important job,record also in your cameras,or in a 2nd pc or an external device.. This is my personal experience
Thanks guys for your help. I will try those things it could help, it sure wouldn't hurt, thanks again!
