rovcen
#1 Posted : Friday, April 5, 2024 11:13:06 AM(UTC)
rovcen
I see there is a way to import a PowerPoint presentation. Is there also a way to import a Propresenter 6 presentation to use as a PIP?
#2 Posted : Friday, April 5, 2024 7:46:06 PM(UTC)
@ rovcen
vMix has this guide on how to use ProPresenter in your production:
https://www.vmix.com/kno...d-propresenter-using-ndi
There are also several methods for capturing PowerPoint presentations into vMix as explained in these videos:
Roy Sinclair
#3 Posted : Saturday, April 6, 2024 8:51:39 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Note that either the vMix Desktop Capture program or the NDI Tool Studio Monitor program can capture the Propresenter 6 screens from your PC or Mac with Propresenter and make an NDI output that vMMix can then pick up and use as an input.
Picture in a picture is then just adding that input as Layer and setting it's size and position or setting it up as a "PictureInAPicture" type overlay which you can toggle on and off.
