I see there is a way to import a PowerPoint presentation. Is there also a way to import a Propresenter 6 presentation to use as a PIP?
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Note that either the vMix Desktop Capture program or the NDI Tool Studio Monitor program can capture the Propresenter 6 screens from your PC or Mac with Propresenter and make an NDI output that vMMix can then pick up and use as an input.
Picture in a picture is then just adding that input as Layer and setting it's size and position or setting it up as a "PictureInAPicture" type overlay which you can toggle on and off.
