Feature Requests
Honor Transitions on all OUTPUTs
I record different versions of my recordings but anything recorded for OUTPUT 2 is dramatically less quality because the inputs do not transition the way I would for OUTPUT 1.
My Inputs are set to move programmed layers from one input to the next in Active (OUTPUT1). Assets on layers will Merge/Move or Fade in predictable ways as I execute one Input and then the next Input. As such with the MERGE Transition, I can move a camera or an image on OUTPUT1 by selecting between Inputs where the assets are placed in different positions. I record my Active (OUTPUT 1) for 16x9 format.
I also record a 9x16 format via OUTPUT2. Every input that I select to record for OUTPUT1, will also trigger a separate Input to move to OUTPUT2. OUTPUT 2 will not honor any transitions and will always execute CUT transition.
I want my 16x9 recording and 9x16 recording to both execute the same way, so I need vMix to honor the transitions for more than just OUTPUT1.
@ sagaofsage
The solution is to use the Mix Input on Output 2/3/4 if you want "Transitions". (otherwise changing the Source on auxiliary Outputs 2/3/4 will always be a "Cut")
Feature Requests
