huggybear
#1 Posted : Friday, March 22, 2024 3:18:59 AM(UTC)
huggybear
Canada
I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila!
#2 Posted : Friday, March 22, 2024 3:51:03 AM(UTC)
How about selecting mutiple videofiles (file explorer) and drag to the vMix Gui ?
huggybear
#3 Posted : Friday, March 22, 2024 4:19:53 AM(UTC)
huggybear
Canada
Well, that does sort of work. The problem is it automatically puts it on the end of the inputs. So, I have to then manually drag it to the input number I want. Takes about the same amount of time either way. Was hoping I could assign the starting input number than batch load beginning at that number.
Thanks for the reply,
JT
