Joined: 9/3/2020(UTC) Posts: 16  Location: British Columbia Thanks: 1 times
I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila!
Originally Posted by: huggybear  I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila! How about selecting mutiple videofiles (file explorer) and drag to the vMix Gui ?
Originally Posted by: doggy  Originally Posted by: huggybear  I would love to be able to batch load video inputs. Just pick a starting number input and multi-select the import files and voila! How about selecting mutiple videofiles (file explorer) and drag to the vMix Gui ? Well, that does sort of work. The problem is it automatically puts it on the end of the inputs. So, I have to then manually drag it to the input number I want. Takes about the same amount of time either way. Was hoping I could assign the starting input number than batch load beginning at that number. Thanks for the reply, JT
