2 Pages12>
JoshTheRadioDude
#1 Posted : Saturday, February 22, 2020 4:13:47 AM(UTC)
JoshTheRadioDude
I thought this had been possible at one point in time, but I may be misremembering things.
Here's my case: I have a daily segment that varies in length each day. I've succeeded in using triggers to automate most of the things that need to happen when I play and stop it, but there's one problem. I want to use an overlay as a two-second transition between that segment and the next, but I also want to fade out the audio while that transition is taking place. With triggers functioning as they do now, the overlay will fire perfectly fine when the segment stops, and I can delay it to fire off later, but I need it to start one second earlier, before the end of the video, to get the audio to fade out during that last second (which is the first second of the transition overlay).
I've tried doing this manually with the stinger function, but it simply cuts the audio off (even though I have all automatic audio switches turned off). The only other option is to fade the audio out in the video file itself, but then that leaves me with two seconds of dead air. I'm trying to tighten up my presentation, not loosen it. I've seen other people attempting to accomplish this with a combination of triggers and timers, but that seems overly complicated, and I would have to set the timer for however long the video is every day, which kind of defeats the whole purpose of automating it in the first place: it's just another step of work for me. I'd like to be able to render the file out in Premiere each morning, have it be in that input when I open vMix, and not have to worry about it at all.
The only way I can think of to make this possible is to allow for negative delays in the OnCompletion trigger. vMix is already keeping track of the time left in the video to display under the viewports, anyway, so it seems technically feasible.
Is this at all a possibility? Would anyone else find this useful?
#2 Posted : Saturday, February 22, 2020 5:26:14 AM(UTC)
With a script one can check the remaining time of a clip and go from there. It does involves a bit of math
dmwkr
#3 Posted : Saturday, February 22, 2020 6:11:04 PM(UTC)
dmwkr
Doggy's hint puts you on the right track, but if you're not into scripting yet and are willing to do it manually, you could possibly trigger a fade transition or/and SetVolumeFade on OverlayIn, or put multiple shortcuts on one key... You'd still have to fire that shortcut at the right time, though.
#4 Posted : Saturday, February 22, 2020 11:22:41 PM(UTC)
@ JoshTheRadioDude
If you know the length of the video, you could set up a timer that is just shy of that and use the "OnCountdownCompleted" Trigger.
It is a little more complex to setup than your suggestion of a "negative delay", but will work exactly as you want.
#5 Posted : Sunday, February 23, 2020 12:15:43 AM(UTC)
Code:
' Checking time left of active input
' and do some stuff at certain time remaining
dim position as string = ""
dim duration as string = ""
dim activeinput as string = ""
dim Timeleft as double = 0
dim triggertime as integer = 2000       '2 seconds before end
dim triggerduration as integer = 2000   'fade duration, could be different than trigger
do while true
   dim xml as string = API.XML()
   x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText)
duration = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@duration").Value)
position = (x.SelectSingleNode("//input[@number='"& activeinput &"']/@position").Value)
Timeleft= Double.Parse(duration)-Double.Parse(position)
if Timeleft < triggertime
  API.Function("SetVolumeFade",Input:=activeinput.tostring(),Value:="0," & triggerduration.tostring())
  ' do whatever one wants to do
end if
sleep(500)
Loop
thanks 2 users thanked doggy for this useful post.
dmwkr on 2/23/2020(UTC), JoshTheRadioDude on 2/25/2020(UTC)
JoshTheRadioDude
#6 Posted : Tuesday, February 25, 2020 4:09:49 AM(UTC)
JoshTheRadioDude
Originally Posted by: IceStream Go to Quoted Post
@ JoshTheRadioDude
Like I said, the length of the video changes from day to day, so while I could possibly time it out that way, that somewhat defeat the purpose. I'd like to just render it out and have it ready to go without having to program anything else in.
#7 Posted : Tuesday, February 25, 2020 4:22:51 AM(UTC)
@ JoshTheRadioDude
Use the posted script
JoshTheRadioDude
#8 Posted : Tuesday, February 25, 2020 4:39:50 AM(UTC)
JoshTheRadioDude
I will give that a shot, but again, this is something that would be much simpler if it were just a function in vMix. I would like to see it added if at all possible.
vvcvvc
#9 Posted : Tuesday, February 25, 2020 9:57:21 PM(UTC)
vvcvvc
Estonia
+1 for Negative Delay
thanks 1 user thanked vvcvvc for this useful post.
JoshTheRadioDude on 2/29/2020(UTC)
spiro67
#10 Posted : Sunday, February 7, 2021 7:33:17 PM(UTC)
spiro67
South Africa
+1 as well!
#11 Posted : Sunday, February 7, 2021 7:47:12 PM(UTC)
Originally Posted by: spiro67 Go to Quoted Post
+1 as well!
Use the script above
as of 12 months (1 year) ago those (few) who needed it seemed happy with the solution ;-)
renevane
#12 Posted : Monday, June 21, 2021 2:05:41 PM(UTC)
renevane
Netherlands
+1 as well!
Scripting is only available in 4K and Pro versions.
÷1 for Negative delay on OnCompletion triggers
#13 Posted : Monday, June 21, 2021 2:24:11 PM(UTC)
Just like several other options and extras ;-)
create external script/app then
renevane
#14 Posted : Monday, June 21, 2021 4:22:30 PM(UTC)
renevane
Netherlands
What I meant was that not everybody is able to employ a script when their vMix edition doesn't support scripting.
I think negative delay times for the OnCompletion trigger would be a great feature to have!
By the way: negative delays are already a 'thing' in vMix (in the audio settings for an input).
So to request it as a feature for an OnCompletion trigger does not seem far fetched.
Here's hoping ;-)
#15 Posted : Monday, June 21, 2021 6:34:53 PM(UTC)
Not true as mentioned before you can create a script externally (as was done - and still done - before vMix scripting was introduced )
Then you have no problem in which license it is used
Can't compare audio and video
renevane
#16 Posted : Monday, June 21, 2021 6:47:54 PM(UTC)
renevane
Netherlands
Understand, but being able to do scripting outside vMix doesn't invalidate a feature request. Not everybody is a programmer. Also, it would be a lot less complicated being able to do it in vMix.
Anyway, I'm not here to start a long discussion. Just +1'ing the original suggestion. ;-)
mrmazure
#17 Posted : Saturday, November 26, 2022 10:47:54 PM(UTC)
mrmazure
+1
gpdipalmerahtimur
#18 Posted : Monday, November 28, 2022 12:11:00 PM(UTC)
gpdipalmerahtimur
Indonesia
+1
jip
#19 Posted : Thursday, March 14, 2024 3:51:37 AM(UTC)
jip
Estonia
+1
This would be definitely a worthwhile improvement for smoother transitions from video inserts back to live.
spinfold
#20 Posted : Thursday, March 14, 2024 10:20:10 AM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
+1
2 Pages12>
