When I make changes to the recording setup, for example changing the WMV bit rate from the default of 800000 to 4000000, I hit OK to save then close the window. When I again open the recording setup window, the change is not shown. The default setting of 800000 is displayed even though recordings use the prior setting of 4000000. These settings should only change when I edit them. The record settings are not saved with the preset. Record settings are lost when I close the program. As stated in another message, all user configurable settings should be saved in the preset. Hope this is corrected in the next version!
Thanks!
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Thanks for the suggestion, the ability to save all recording settings will be available in the next version.
Martin vMix
