kirbyk48
#1 Posted : Sunday, March 10, 2024 11:21:23 PM(UTC)
kirbyk48
I have been using an Atem Mini for 2 years as a camera input to vMix without any problems. This week, when I loaded the preset the colors are the inverse of reality. Looks like an old Ektachrome slide reverse processed. I don't know if the problem originates in the Atem or vMix. Any help is appreciated.
#2 Posted : Monday, March 11, 2024 3:25:41 AM(UTC)
@ kirbyk48
Check the vMix Settings ==> Colour Adjust on the Input.
By default:
Black Stretch should be 0
White Stretch should be 255
(these may be reversed, or you can reverse them to invert the colours of the Input)
kirbyk48
#3 Posted : Monday, March 11, 2024 7:07:40 AM(UTC)
kirbyk48
They are set to the correct defaults, but I'll check again when I go back to church on Wednesday. Thanks
