Camera input colors inverted - Help!!
I have been using an Atem Mini for 2 years as a camera input to vMix without any problems. This week, when I loaded the preset the colors are the inverse of reality. Looks like an old Ektachrome slide reverse processed. I don't know if the problem originates in the Atem or vMix. Any help is appreciated.
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ kirbyk48
Check the vMix Settings ==> Colour Adjust on the Input. By default: Black Stretch should be 0 White Stretch should be 255 (these may be reversed, or you can reverse them to invert the colours of the Input)
They are set to the correct defaults, but I'll check again when I go back to church on Wednesday. Thanks
