Henny
#1 Posted : Sunday, March 3, 2024 5:11:41 AM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Eventing All
Just used the Zoom integration to bring in a presenter to a Hybrid Event and although I could see the presenter's mouse moving and pointing at stuff on their screen share on the Zoom laptop that I was using to manage the meeting the screen share coming into vMix had no mouse pointer.
thanks
ian
blfox33
#2 Posted : Monday, March 4, 2024 11:02:49 AM(UTC)
blfox33
I have had similar issues with using an app called ZoomISO to bring zoom calls into VMIX via NDI. I was hoping VMIX27 would not suffer the same problem. It's a real issue when trying to demonstrate / teach software live.
knbPixels
#3 Posted : Wednesday, July 3, 2024 11:53:23 PM(UTC)
knbPixels
Same here
knbPixels
#4 Posted : Friday, July 12, 2024 11:57:06 PM(UTC)
knbPixels
Would love some feedback from the admins on if this will be able to be fixed?
#5 Posted : Saturday, July 13, 2024 10:33:11 PM(UTC)
@ knbPixels
Apparently, this is a "bug" or oversight in the ZOOM SDK that does not have an option to enable the view for the cursor, so not much vMix can do until ZOOM addresses that.
A possible "workaround" solution is to enable the highlight around the cursor (Annotate ==> Spotlight), which will display (not ideal, but will work).
knbPixels on 7/15/2024(UTC)
knbPixels
#6 Posted : Tuesday, July 16, 2024 12:12:44 AM(UTC)
knbPixels
I actually got some clarification from Zoom, and while I won't go into the details of why the screen share in Zoom is able to display the cursor and vMix isn't able to see it...I will say it should be possible for Zoom to make a provision for this, but I don't believe a fix is in the works.
thanks 1 user thanked knbPixels for this useful post.
richardgatarski on 7/16/2024(UTC)
JofrePCG
#7 Posted : Friday, July 19, 2024 11:57:42 PM(UTC)
JofrePCG
Brazil
On Zoom there is a question about the lack of this feature: https://devforum.zoom.us...ta-screen-sharing/111392
I don't understand much, but is vmix unable to develop based on this limitation?
knbPixels
#8 Posted : Wednesday, July 24, 2024 12:17:22 AM(UTC)
knbPixels
A fix would have to come from Zoom. Zoom needs to either include the pointer as part of the screen share instead of faking it, or pass the Mouse XY coordinates it is using anyway to vMix so that vMix could fake it in the same that Zoom does.
JofrePCG on 7/24/2024(UTC)
blfox33
#9 Posted : Thursday, October 24, 2024 6:07:28 AM(UTC)
blfox33
We have solved this problem! Try having guests login to zoom via a web browser, as opposed to the app. The pointer is back during screenshares!
thanks 1 user thanked blfox33 for this useful post.
JofrePCG on 10/24/2024(UTC)
