peter436
#1 Posted : Thursday, February 29, 2024 9:14:39 PM(UTC)
peter436
Netherlands
I have a zoom input that I use to stream to a Webinar.
The audio source in the zoom input is set to the Master bus.
When I route an audio input direct to the master bus the audio reaches my zoom input like it should.
But when I route an audio input to an other bus and send this bus to the master I don't get any audio in my zoom call.
The audio does go to my main output and recording.
Is this normal?
What can I do to make this work?
dmwkr
#2 Posted : Thursday, February 29, 2024 9:21:36 PM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
I guess it is the same reason why this does not work for vMix Calls:
Sending Audio Bus to Master
Click the M button underneath buses A-G to include the audio in Master and Headphones.
Note: vMix Call Master/Headphones audio excludes any buses sent to master using this method as doing so would prevent mix minus from working correctly.
https://www.vmix.com/help27/Mixer.html
peter436
#3 Posted : Friday, March 1, 2024 1:57:34 AM(UTC)
peter436
Netherlands
I think you're right dmwkr.
Thanks for pointing this out.
Unfortunately this means I have to change my workflow.
But that's ok.
