Zoom, no audio when bus send to master
I have a zoom input that I use to stream to a Webinar. The audio source in the zoom input is set to the Master bus. When I route an audio input direct to the master bus the audio reaches my zoom input like it should. But when I route an audio input to an other bus and send this bus to the master I don't get any audio in my zoom call. The audio does go to my main output and recording.
Is this normal? What can I do to make this work?
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
I guess it is the same reason why this does not work for vMix Calls: Quote:Sending Audio Bus to Master
Click the M button underneath buses A-G to include the audio in Master and Headphones. Note: vMix Call Master/Headphones audio excludes any buses sent to master using this method as doing so would prevent mix minus from working correctly. https://www.vmix.com/help27/Mixer.html
I think you're right dmwkr. Thanks for pointing this out. Unfortunately this means I have to change my workflow. But that's ok.
