Custom text for countdown to set time
I have a countdown timer that counts down to 11:00 AM. The problem is that I don't see any default ability to have a custom text for when it reaches 11. It just shows zeros.
I've seen some scripts that change the colors of timers as they near the end (but not count down to specific time). but not seen one yet that will hide the 00 and display a different text. I know enough to customize an existing script a bit. but not make something new that I don't have an example to follow. Can someone help me figure this out.
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 322 time(s) in 184 post(s)
Originally Posted by: ArchThunder  I have a countdown timer that counts down to 11:00 AM. The problem is that I don't see any default ability to have a custom text for when it reaches 11. It just shows zeros.
I've seen some scripts that change the colors of timers as they near the end (but not count down to specific time). but not seen one yet that will hide the 00 and display a different text. I know enough to customize an existing script a bit. but not make something new that I don't have an example to follow. Can someone help me figure this out. Use a trigger "OnCountdownCompleted" with command "SetText" and set the 'Time.txt' to the text you want to display.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
I've seen some scripts that change the colors of timers as they near the end (but not count down to specific time). but not seen one yet that will hide the 00 and display a different text. I know enough to customize an existing script a bit. but not make something new that I don't have an example to follow. Can someone help me figure this out. From the description i asume your are using a countdown to time (clocks) . In that the case a OnCountdownCompleted will not work (respond) Can be solved using a script checking the API XML to check what is displayed in the title and do the setText option when 00:00:00 like Raugert Explained Timers <> Clocks
Originally Posted by: doggy  Originally Posted by: ArchThunder  I have a countdown timer that counts down to 11:00 AM. The problem is that I don't see any default ability to have a custom text for when it reaches 11. It just shows zeros.
I've seen some scripts that change the colors of timers as they near the end (but not count down to specific time). but not seen one yet that will hide the 00 and display a different text. I know enough to customize an existing script a bit. but not make something new that I don't have an example to follow. Can someone help me figure this out. From the description i asume your are using a countdown to time (clocks) . In that the case a OnCountdownCompleted will not work (respond) Can be solved using a script checking the API XML to check what is displayed in the title and do the setText option when 00:00:00 like Raugert Explained Timers <> Clocks CorrectionUsing countdown to time will NOT display the current remaining time in the title but rather the timestring as set so above mentioned is not possible However one can use this script (adjusted to your needs) to run simultaniously https://forums.vmix.com/...ng-for-Dummies#post74242
Yes I was using the countdown to time clock feature, but figured it wasn't going to work out and I needed to move to a script.
That link you shared looks to have what I want. thanks.
