crnaman77
#1 Posted : Thursday, February 22, 2024 9:43:00 AM(UTC)
crnaman77
So, I have created "input at this position" inputs for all the ptz presets of all the cameras and assigned them each one to a stream deck button to load in preview. This all works fine. (stream deck xl, each long row represents one camera with an empty button on the end)
Then I was trying to create an activator for each input to turn the last button red when it is live, as a visual cue that that camera is live and not to try to ptz it.
The first activator I made works, but any activator I make after that for the other inputs do not work for the same button.
Why can't we have multiple activators for one button?
Thanks.
#2 Posted : Thursday, February 22, 2024 4:32:34 PM(UTC)
Thanks.
Try this
https://forums.vmix.com/...ng-for-Dummies#post98564
should do the trick
but why not the button for the specific camera PTZ position ? Then you have indication of Camera AND position
dmwkr
#3 Posted : Thursday, February 22, 2024 7:10:53 PM(UTC)
dmwkr
It is also possible to set an "OnTransitionIn" trigger on your virtual inputs, that sets the parent input (original input of the PTZ camera) as "ActiveInput". Then just use the activator for the parent input on your buttons. (Of course, this only works if you don't have individual Color Corrections on the virtual inputs.)
Also, Bitfocus Companion allows for multiple activators on one button.
thanks 1 user thanked dmwkr for this useful post.
crnaman77 on 2/22/2024(UTC)
crnaman77
#4 Posted : Thursday, February 22, 2024 10:38:59 PM(UTC)
crnaman77
Doggy, I have thumbnail enabled for preview of ptz shot on the ptz button and vmix insists this is priority and will not allow color change to stick.
Dmwkr, your suggestion is working and very simple, adding to that a delay longer than the transition time. Thanks.
#5 Posted : Thursday, February 22, 2024 11:07:59 PM(UTC)
Ok as you failed to mention that , but using the DynamicInputx works just fine (tested) for your end row button
