Joined: 7/23/2020(UTC) Posts: 6  Location: Texas Thanks: 1 times
Hello, I have a live production coming up and I Will have 50 different lower thirds to insert during the production. What is the easiest way to call them and insert them live.? Its a one Man operation so I Will be switching cameras as well in the vmix. Thank you so much I appreciate your suggestions.
Originally Posted by: ArmandTanzarian  Hello, I have a live production coming up and I Will have 50 different lower thirds to insert during the production. What is the easiest way to call them and insert them live.? Its a one Man operation so I Will be switching cameras as well in the vmix. Thank you so much I appreciate your suggestions. What is the difference between each lower third ?
Originally Posted by: doggy  Originally Posted by: ArmandTanzarian  Hello, I have a live production coming up and I Will have 50 different lower thirds to insert during the production. What is the easiest way to call them and insert them live.? Its a one Man operation so I Will be switching cameras as well in the vmix. Thank you so much I appreciate your suggestions. What is the difference between each lower third ? Each lower third has a different name for a runway model. Its a fashion show.
Then you only need one Title/input and can change the content (names) by using a datasource . Select the row containing the desired name from the list to display in the title , or if they are in order you can usse shorctus to advance a row when needed ( have one to go back a row too, you now whne using it yhat you needed it ;-) )
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
The data source is great, but I have a way I use...I use Panel Builder, and have an input where I load as many titles as I want, and I can scroll through them as fast as I want, and I can see what each title says... you can make PB as small as you want, and place it anywhere on vMix GUI...where it will not obstruct the view of something that you need to look at often...for me, I place mine over the Preview window, as I know which camera I am switching to, and do not need the previewthat much, if ever at all....it works great for me...I use it all the time, even to play commercials, etc...and, all on a single screen...No... I am not a crazy person, but it is what I do...one large monitor so I have room for that
 1 user thanked Luis70 for this useful post.
Thank you for your help I Will explore all these options
