ArmandTanzarian
#1 Posted : Wednesday, February 14, 2024 4:32:32 PM(UTC)
ArmandTanzarian
I have a live production coming up and I Will have 50 different lower thirds to insert during the production. What is the easiest way to call them and insert them live.? Its a one Man operation so I Will be switching cameras as well in the vmix.
Thank you so much I appreciate your suggestions.
#2 Posted : Wednesday, February 14, 2024 5:52:51 PM(UTC)
Originally Posted by: ArmandTanzarian Go to Quoted Post
What is the difference between each lower third ?
ArmandTanzarian
#3 Posted : Wednesday, February 14, 2024 10:49:36 PM(UTC)
ArmandTanzarian
Each lower third has a different name for a runway model. Its a fashion show.
#4 Posted : Thursday, February 15, 2024 1:00:58 AM(UTC)
Then you only need one Title/input and can change the content (names) by using a datasource .
Select the row containing the desired name from the list to display in the title , or if they are in order you can usse shorctus to advance a row when needed ( have one to go back a row too, you now whne using it yhat you needed it ;-) )
Luis70
#5 Posted : Thursday, February 15, 2024 2:49:14 AM(UTC)
Luis70
Grenada
Was thanked: 8 time(s) in 8 post(s)
The data source is great, but I have a way I use...I use Panel Builder, and have an input where I load as many titles as I want, and I can scroll through them as fast as I want, and I can see what each title says... you can make PB as small as you want, and place it anywhere on vMix GUI...where it will not obstruct the view of something that you need to look at often...for me, I place mine over the Preview window, as I know which camera I am switching to, and do not need the previewthat much, if ever at all....it works great for me...I use it all the time, even to play commercials, etc...and, all on a single screen...No... I am not a crazy person, but it is what I do...one large monitor so I have room for that
thanks 1 user thanked Luis70 for this useful post.
ArmandTanzarian on 2/15/2024(UTC)
ArmandTanzarian
#6 Posted : Thursday, February 15, 2024 7:22:52 AM(UTC)
ArmandTanzarian
Thank you for your help I Will explore all these options
