4 Pages123>»
#1 Posted : Monday, January 22, 2024 12:43:38 PM(UTC)
vMix 27 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Thanks,
thanks 9 users thanked admin for this useful post.
QuiapoChurch on 1/22/2024(UTC), jf_blanco on 1/22/2024(UTC), richardgatarski on 1/22/2024(UTC), Sobhanbabu on 1/22/2024(UTC), eduardocfs on 1/22/2024(UTC), DaleBru on 1/22/2024(UTC), nikosman88 on 1/22/2024(UTC), raugert on 1/23/2024(UTC), stigaard on 1/24/2024(UTC)
ovonder
#2 Posted : Monday, January 22, 2024 10:20:11 PM(UTC)
ovonder
During upgrade from .55 i get a blocking error
c:\program files (x86)\vmix\vcmwrapper.dll
access is denied.
I was running vmix .55 pressed check for update and installed update while vmix was still running.
Even after i closed vmix and tried retry, it did not work.
I had to abort then i installed from \documents, but ran into the same warning.
richardgatarski
#3 Posted : Monday, January 22, 2024 10:22:54 PM(UTC)
richardgatarski
Hurray for the release!
Could you please consider being a bit more explicit about the Zoom Plugin versioning. I understand that the Zoom Plugin is not always updated whenever vMix is updated. Perhaps vMix could warn if the Zoom Plugin is outdated, ideally when vMix is installed or started?
There is also a slightly confusing "Last Updated" info on the Zoom Plugin download page. One can easily understand that as when the Plugin was updated, but I guess it is when the download web page was updated...
Thanks!
papaswan on 1/25/2024(UTC)
lrrangel
#4 Posted : Monday, January 22, 2024 11:45:13 PM(UTC)
lrrangel
Brazil
Same Here
Restart your pc and try again. Works!
access is denied.
#5 Posted : Monday, January 22, 2024 11:49:15 PM(UTC)
Thanks!
vMix already does this. It will provide a message within vMix when adding or opening a Zoom input and a button to download an update if required.
#6 Posted : Monday, January 22, 2024 11:49:48 PM(UTC)
access is denied.
This means you have a program running on the computer that is blocking vMix.
Restart the computer and ensure all programs are closed before updating.
lrrangel on 1/22/2024(UTC)
richardgatarski
#7 Posted : Tuesday, January 23, 2024 12:51:51 AM(UTC)
richardgatarski
Before asking about this I installed the Zoom Plugin that was released for beta 27.0.0.49, and did not get any warning when trying to add a Zoom Input.
Universum
#8 Posted : Wednesday, January 24, 2024 5:30:33 AM(UTC)
Universum
Canada
So it seems the abilty to add frame delay with a shortcut doesnt apply to audio sources. I guess i expected that when it was called "frame delay" and was just wishful thinking on my part. Just wanted to make sure i wasnt missing something or doing something wrong. Is this something that might be added anytime soon?
stevemol
#9 Posted : Wednesday, January 24, 2024 9:45:36 PM(UTC)
stevemol
The Zoom plugin is pretty nice - but since I really need a preview/monitor screen on the input, I thought I'd try to use NDI Monitor since all of my video inputs are available on NDI. Much to my dismay, the Zoom input is not listed. That makes it unusable for me at this point. Please add the Zoom input(s) to the NDI list!
dmwkr
#10 Posted : Wednesday, January 24, 2024 9:48:48 PM(UTC)
dmwkr
https://forums.vmix.com/...--Audio-Inputs-NDI-feeds
richardgatarski
#11 Posted : Wednesday, January 24, 2024 10:08:20 PM(UTC)
richardgatarski
You can send the Zoom Input to one of Output2/3/4, and turn NDI on for the chosen Output.
NMG4
#12 Posted : Wednesday, January 24, 2024 11:25:39 PM(UTC)
NMG4
Ireland
Updated,imputs work for a moment then everything goes blank and will not work?
#13 Posted : Thursday, January 25, 2024 2:39:02 AM(UTC)
This can happen if vMix was not installed correctly, i.e due to some other malfunctioning software blocking it from installing some files.
Restart the computer, close all applications and install vMix again.
Porter67
#14 Posted : Thursday, January 25, 2024 6:42:48 AM(UTC)
Porter67
Hello vMix,
I have been trying out to zoom feature in 27 and I can connect but no video and audio or FPS comes through. I have watched your video several times and I have checked my Account setting, turn off auto record, enabled HD Quality and disabled mute all participants when they join, what am I doing wrong or is there something I'm missing?
slb5146
#15 Posted : Thursday, January 25, 2024 9:37:58 AM(UTC)
slb5146
Layers Designer error message - How to get around this error and use the designer:
Layer Designer Disabled while input's Main position has been changed.
Roy Sinclair
#16 Posted : Thursday, January 25, 2024 9:51:01 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Possible bug,
Sunday morning (vMix 26.0.0.45) and we lost our outbound USB connection to our M32 sound board though the inbound connection was still working fine. Specifically, we couldn't get vMix to make the connection though there was no visible indication of a connection problem.
The output from vMix to the M32 uses the ASIO "Klark Teknik DN32-Live" driver with the output being on channels 3+4 output from vMix Bus A. This allows us to play videos in vMix to the sound system but not have it feed that audio back to the output stream. Since our Preacher was under quarantine with Covid, he had recorded his sermon from home and sent it to us. At the last moment we hooked up a Behringer UMC 204 and switched vMix to output using that and it worked.
One of the things we checked was setting Windows Audio to the DN32 driver output and using media player we could send the audio through those channels so we verified that it was not a problem with the drivers or the M32 connection so it had to be a problem in vMix.
As expected when I started vMix today it remained non-functional, however I noticed the new version and downloaded and installed it. After the upgrade vMix now works with the driver again.
The question: Is there some sort of log hidden away where I can see what sort of problem vMix was having before that upgrade?
#17 Posted : Thursday, January 25, 2024 12:29:37 PM(UTC)
Originally Posted by: Porter67 Go to Quoted Post
Hello vMix,
Double check all the items under Zoom Troubleshooting:
https://www.vmix.com/hel...ZoomTroubleshooting.html
If all else fails, please contact us and send a support report when prompted:
https://www.vmix.com/contact-us.aspx
#18 Posted : Thursday, January 25, 2024 12:32:12 PM(UTC)
As indicated in the error, you will need to go into the Position tab and click Reset All for Main, as the layer designer does not work if adjustments are made to the main layer holding all the others.
slb5146 on 1/25/2024(UTC)
richardgatarski
#19 Posted : Friday, January 26, 2024 2:32:13 AM(UTC)
richardgatarski
Can admin confirm that vMix27 only supports Zoom Meetings, not Webinars (as a forum member of Streaming idiots have stated).
I have tried, and it does not work if vMix tries to join a Webinar that allows local recording for participants and following all the other trouble shooting advice. I cannot currently host a Webinar as I have no such license on our account. When I try to connect to the Webinar I get the message "Connecting..." - and I am stuck. Left-click "Connecting" is greyed out, even after the Webinar has ended. Fix is by closing ALL the Zoom Inputs, and then regretting the last close. This reinstates the Input with a blue "Click here to connect" banner.
Also, I cannot from vMix join a Meeting hosted by a Zoom Room. It seems to connect, and the Zoom Room can Admit vMix. Initially there is no mike icon, and the camera icon is red, for vMix in the Zoom Room Control panel's list of Participants. If I on the Zoom Rooms control panel asks vMix to turn the camera on, the icon becomes black but still no mike icon. The Zoom Input in vMix is black and no sound. Hosting a meeting in vMix, and join from a Zoom room to it works fine. As does joining a meeting hosted by someone else, and with a Zoom Room joined to that meeting.
#20 Posted : Friday, January 26, 2024 2:54:05 AM(UTC)
vMix 27 supports Zoom Meetings only. Note that our documentation only refers to Zoom Meetings as a result.
rogerone on 1/27/2024(UTC)
4 Pages123>»
