28 Pages«<2324252627>»
richardgatarski
#481 Posted : Monday, January 22, 2024 9:43:48 PM(UTC)
richardgatarski
I would like to have a script read some custom settings stored in a .txt file stored in the same folder as the .vmix and .config files (that contains the script). Whereas when Presets are opened vMix defaults to search for unfound files used for Inputs in that folder, I guess that there is no way to get the filePath to it in a vMix script? Please tell me that I am wrong...
Side note, here is what ChatGPT offered me as the solution for parsing the content of the .txt file. Just had to remove the the Imports, Module, and Sub stuff and the script worked.
Imports System.IO
Module Module1
Sub Main()
' Define your variables
Dim varA As String
Dim varB As String
Dim varC As String
' Specify the path to your .txt file
Dim filePath As String = "path\to\your\file.txt"
' Read all lines from the file
Dim lines() As String = File.ReadAllLines(filePath)
' Process each line
For Each line As String In lines
' Split the line into variable name and value
Dim parts() As String = line.Split("="c)
' Check if the line is formatted correctly
If parts.Length = 2 Then
Dim variableName As String = parts(0).Trim()
Dim variableValue As String = parts(1).Trim()
' Assign the value to the corresponding variable
Select Case variableName
Case "varA"
varA = variableValue
Case "varB"
varB = variableValue
Case "varC"
varC = variableValue
' Add more cases for other variables if needed
End Select
Else
' Handle lines with incorrect format
Console.WriteLine("Error: Line has incorrect format - " & line)
End If
Next
' Now, your variables varA, varB, and varC should have the values from the file
Console.WriteLine("varA: " & varA)
Console.WriteLine("varB: " & varB)
Console.WriteLine("varC: " & varC)
' Optionally, you can do further processing or display the values as needed
Console.ReadLine() ' Keep console window open (press Enter to close)
End Sub
End Module
#482 Posted : Monday, January 22, 2024 11:27:24 PM(UTC)
the folder location of the loaded preset file can be found in the current API.XML
For the location of scripts it depends if the scripts are local or general (within preset or config file)
For the config file itself it is dependant on the version of vMix installed
? for the location of where they are supposed to be (yes they are in the presetfile)
Code:
Dim FileReader As System.IO.StreamReader
Dim InputLine As String
FileReader = System.IO.File.OpenText("d:/realine.txt")
InputLine = FileReader.ReadLine()
Do Until InputLine is Nothing
     Console.WriteLine(InputLine)
     'can do content of line manipulation here
Loop
richardgatarski
#483 Posted : Tuesday, January 23, 2024 1:14:31 AM(UTC)
richardgatarski
Aarg! You got me there. When I tried I did not load a Preset, I just created a new one without saving it. I think that will make me an advanced member of Streaming Idiots...
Thanks though doggy!
#484 Posted : Tuesday, January 23, 2024 2:26:27 AM(UTC)
LOL
There is always the last.vmix preset that is automatically updated ;-) (every minute)
Gary2theO
#485 Posted : Thursday, January 25, 2024 7:10:40 AM(UTC)
Gary2theO
Auto Play/Audio with Mix transitions
For clearly stated reasons Mix transitions do not follow the general input rules of autoplay and audio.
In the latest vMix video Tim gives some options using shortcuts and triggers.
Here is another option example:
There is no check to see if the Mix is in Output, in overlay or part of a multiview or even check on multiple Mix inputs in this script but are easely added if so needed. Am sure you can figure it out how to add ;-)
And yes there will be a slight action delay if one uses other transitions than Cut in the Mix (obviously)
This an auto variation of https://forums.vmix.com/...ng-for-Dummies#post97309
Code:
dim MixNumber as string = "2"
dim oldactive as string = ""
dim Mactive as string = ""
dim Mpreview as string = ""
do while true
  x.loadxml(API.XML())
  Mactive = (x.SelectSingleNode("//mix[@number='" & MixNumber & "']/active/text()").InnerText)
  Mpreview = (x.SelectSingleNode("//mix[@number='" & MixNumber & "']/preview/text()").InnerText)
  if oldactive <> Mactive then
    API.Function("Play",Input:=Mactive)
    API.Function("AudioOn",Input:=Mactive)
    API.Function("Pause",Input:=Mpreview)
    API.Function("AudioOff",Input:=Mpreview)
    oldactive = Mactive
  end if
loop
Looking for some help with this script. I am using it to control the audio in Mix2 for when I am doing some PiP stuff. The script itself works great but my only issue is that the audio of the active input gets turned off when I transistion in my PiP input. I know that's because the input itself is transitioning out. As I switch through different inputs, the audio of the selected input it turned on, it's really that initial transition to Mix2 that is my issue. Is there something I am missing or is there another shortcut that I need to create in order to keep the audio on?
For example...
Camera 1 is the active input, audio is ON, and I want to transition to my PiP with camera 1. I transition in PiP input with camera 1 in mix2, audio on camera 1 turns OFF. When I transition to camera 2 in mix2, camera 2 audio turns ON. As I continue to switch through inputs the audio of the active input turns ON, as the script tells it to do.
I just need that initial transition to keep the audio ON.
Any help would be greatly appreciated.
Locke
#486 Posted : Friday, January 26, 2024 12:52:22 AM(UTC)
Locke
Germany
Hey everyone,
after studying this thread for hours and writing a few scripts by my own I came to the point where I can't find a solution
for my problem.
I want to know, which page of a title-input is active. I already figured out how to open a page
Code:
API.Function("TitleBeginAnimation", Input:= "Scoreboard", Value := "Page2")
or alternatively:
Code:
API.Function("SelectIndex", Input:= "Scoreboard", Value := "2")
but I am wondering how to find the active page. I need this to call a specific page under specific circumstances.
In my case (it's for a tennis preset): while the first set show page 1, while the second set show page 2 and so on.
Since I won't use it by myself but give the preset to external users, it has to be easy to handle and nearly unbreakable.
That's why I don't want to use an additional Text as a counter, which I could call in the method.
Any answers would be greatly appreciated!
#487 Posted : Friday, January 26, 2024 2:58:59 AM(UTC)
Originally Posted by: Locke Go to Quoted Post
Hey everyone,
for my problem.
There is no reference (API XML) that lets you know which page is currently active.
You will have to create your own reference system . could use setting a dynamic value based on the page you called for and do a test (vb.net) on it
vMix scripts are always accesible so unbreakable is not an option (unless one creates an external app )
How breakable a script is during use depends on how well a script is designed/written including failsafe tests, error catching etc and catering for any possible misuse (ie testing for any possible scenario)
#488 Posted : Friday, January 26, 2024 3:02:09 AM(UTC)
For example...
what are your automatic audio settings of your active input ?
Gary2theO
#489 Posted : Friday, January 26, 2024 3:28:52 AM(UTC)
Gary2theO
For example...
All my inputs are set to auto mix.
#490 Posted : Friday, January 26, 2024 3:51:11 AM(UTC)
For example...
David BCS
#491 Posted : Wednesday, January 31, 2024 10:49:25 PM(UTC)
David BCS
You have been a member since:: 11/17/2022(UTC)
Hi
Is it possible to get JSON data via API with authorisation via Brearer Token?
Thanks in advance!
richardgatarski
#492 Posted : Wednesday, January 31, 2024 10:58:32 PM(UTC)
richardgatarski
Originally Posted by: David BCS Go to Quoted Post
Hi
Thanks in advance!
Search the Feature request forum.
David BCS on 1/31/2024(UTC)
#493 Posted : Tuesday, February 6, 2024 5:58:43 PM(UTC)
Trigger an action when a (long) transition has finished with approx remain time of transition
discussion https://forums.vmix.com/postmessage?m=112773
Its based on the transition settings on the vMix GUI, transition is called from within this script
Mind you response time in the script editor console is slower than actual say display info in the title
Code:
' One of Transitions (1-4) set in the vMix GUI
dim vTransition as string = "Merge"
dim xml as string = API.XML()
x.loadxml(xml)
'Get the duration of the transition
Dim vDuration as string = x.SelectSingleNode("//transition[@effect='" & Vtransition & "']/@duration").Value
'Input that is currently active
Dim vActive as string = x.SelectSingleNode("//active").InnerText
Dim vElapsed As TimeSpan
Dim watch As Stopwatch = Stopwatch.StartNew()
'Execute the transition
API.Function(vTransition,duration:=vDuration )
Do While true
    xml= API.XML()
    x.loadxml(xml)
    If x.SelectSingleNode("//preview").InnerText = vActive
       ' if preview becomes what was active the transition is done
       console.writeline("Done")
       API.Function("SetText",Input:=1,SelectedName:="Headline.Text" ,Value:="DONE")
       Exit do
    else
       ' a bit of countdon based on the transition duration (formula can be improved)
       API.Function("SetText",Input:=1,SelectedName:="Headline.Text" ,Value:=(vDuration/1000) - Math.Floor(watch.Elapsed.TotalMilliseconds/1000) )
       Console.WriteLine( vDuration/1000 - Math.Floor(watch.Elapsed.TotalMilliseconds/1000))
    end if
    ' sleep(100)
Loop
videokommando
#494 Posted : Thursday, March 21, 2024 10:36:35 PM(UTC)
videokommando
I would like to write the status of Overlay2 to variable.
Example:
Status of Overlay2 = ON or OFF
Can I read the status?
It is possible with VB.NET scripting?
Thank you.
#495 Posted : Friday, March 22, 2024 2:44:40 AM(UTC)
Example:
Yes ( will tell you (if) which input is in overlay equals ON)
Yes
Plenty of examples on how to get various info from the vMix API XML in this thread
videokommando
#496 Posted : Friday, March 22, 2024 5:44:24 AM(UTC)
videokommando
Example:
Yes
Thank you.
Unfortunately I did not find the solution.
I don't know what code to look for.
The file name: is: title.gtzip
Overlay: 2
How can I give a variable a true or false value?
ajfnetwork
#497 Posted : Friday, March 22, 2024 7:00:10 AM(UTC)
ajfnetwork
Venezuela
Hello colleagues, I hope you are well... I have the following question...
It would be possible to make a script, I don't know if it already exists, can someone advise me since I'm new to scripts...
Does it allow me to place titles every time a data source is updated by XML? If I can explain myself correctly...
That every time the XML data source is updated, the title overlay is activated.
I hope you can help me... thank you very much
#498 Posted : Friday, March 22, 2024 4:00:57 PM(UTC)
Example:
Yes
Thank you.
Overlay: 2
Code:
dim TheOverlayOn as Boolean
dim ovl1input as string = ""
do while true
    ovl1input = (x.SelectSingleNode("//overlays//overlay[2]").InnerText)
    if ovl1input > "0"
      TheOverlayOn = True
    else
      TheOverlayOn = False
    end if
    Sleep(1000)
Loop
#499 Posted : Friday, March 22, 2024 4:07:12 PM(UTC)
Read content of title by reading the API XML or using the Input.Find() option
Compare to a previously saved content , if different perform action , save new content for next comparison. Rinse and repeat
PLS go through the multiple examples in this thread on how to read info from the api xml
go through the multiple online tutorials on programming in vb.net
videokommando
#500 Posted : Friday, March 22, 2024 9:24:38 PM(UTC)
videokommando
Code:
do while true
    if ovl1input > "0"
      TheOverlayOn = True
    else
    end if
    Sleep(1000)
Loop
Thank you very much.
Very useful help.
