rtsp string, vmix not recognizes audio
Hi dear team, how i can recognizes the audio from my camera rtsp flux? if i open the flux with vlc player work.
Thank you Alberto
Joined: 1/13/2010(UTC) Posts: 5,307  Location: Gold Coast, Australia Was thanked: 4688 time(s) in 1611 post(s)
Does the stream have AAC audio? vMix only supports RTSP with H264 video and AAC audio.
Martin vMix
Hi dear Martin, my camera is: http://www.amovision.com..._Megapixel_IP_C/594.htmlshe support h264video and not know the audio, i think g711? you can verify on the top link. Thank you Alberto Video Compression H.264 / MJPEG Frame Rate Main Stream 1920*1080 25fps Sub Stream VGA 640*360 25FPS Bit Rate 128Kbps~8Mbps,Supports CBR/VBR Audio Compression G.711 Interface 1/1 channel In/Out
Hi Pagu - please let me know if you can get this working. As far as I know, and I have asked on this forum, there is NO IP camera which gives audio and video into vMix. Just video only.
antardwip wrote:Hi Pagu - please let me know if you can get this working. As far as I know, and I have asked on this forum, there is NO IP camera which gives audio and video into vMix. Just video only. This is incorrect, if the camera supports H264 video and AAC audio both audio and video will work. Cameras without audio usually use g711 which is a low quality audio format and not suitable for use with vMix.
Many thanks - you are right, my present IP camera uses G.711 for audio. I have had questions about this on the forum for six months now you have cleared it up, wonderful. If you know of any models that anyone has actually used and got working, please let me know so I can check it out. Otherwise having already got the wrong one, I feel a bit wary.
