pagu
#1 Posted : Friday, August 1, 2014 11:59:07 AM(UTC)
pagu
Hi dear team,
how i can recognizes the audio from my camera rtsp flux? if i open the flux with vlc player work.
Thank you
Alberto
#2 Posted : Friday, August 1, 2014 12:21:02 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Does the stream have AAC audio? vMix only supports RTSP with H264 video and AAC audio.
pagu
#3 Posted : Saturday, August 2, 2014 11:12:37 AM(UTC)
pagu
Hi dear Martin,
my camera is: http://www.amovision.com..._Megapixel_IP_C/594.html
she support h264video and not know the audio, i think g711? you can verify on the top link.
Thank you
Alberto
Video
Compression
H.264 / MJPEG
Frame Rate
Main Stream
1920*1080 25fps
Sub Stream
VGA 640*360 25FPS
Bit Rate
128Kbps~8Mbps,Supports CBR/VBR
Audio
Compression
G.711
Interface
1/1 channel In/Out
antardwip
#4 Posted : Monday, August 11, 2014 5:08:31 AM(UTC)
antardwip
Hi Pagu - please let me know if you can get this working. As far as I know, and I have asked on this forum, there is NO IP camera which gives audio and video into vMix. Just video only.
#5 Posted : Monday, August 11, 2014 5:28:04 AM(UTC)
This is incorrect, if the camera supports H264 video and AAC audio both audio and video will work.
Cameras without audio usually use g711 which is a low quality audio format and not suitable for use with vMix.
antardwip
#6 Posted : Thursday, August 14, 2014 4:57:11 AM(UTC)
antardwip
Many thanks - you are right, my present IP camera uses G.711 for audio. I have had questions about this on the forum for six months now you have cleared it up, wonderful. If you know of any models that anyone has actually used and got working, please let me know so I can check it out. Otherwise having already got the wrong one, I feel a bit wary.
