Instant Replay
SetRateSlowMotion not working with API call /streamdeck button
Joined: 12/8/2022(UTC) Posts: 168  Thanks: 52 times Was thanked: 3 time(s) in 3 post(s)
Hi! Trying to run a custom command on a streamdeck button in companion with "SetRateSlowMotion" but fail to make it work. If I do a vMix shortcut it works fine. So I think I must be using the wrong setting in companion. Also: if I run the command in the browser it does not work either. So this works:  This does not work (string used is: SetRateSlowMotion&Input=Preview&Value=0.5):  In browser I run this: http://localhost:8088/api/?function=SetRateSlowMotion&Input=Preview&Value=0.5 but speed is not set to 50% But I get response "Function completed successfully." Thanks for any help with this!
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: TL68  Hi! Trying to run a custom command on a streamdeck button in companion with "SetRateSlowMotion" but fail to make it work. If I do a vMix shortcut it works fine. So I think I must be using the wrong setting in companion. Also: if I run the command in the browser it does not work either.
Thanks for any help with this! Try using the specific input name/number instead of preview FYI input number for preview = 0
Thanks for input, Doggy! Got some progress when using input number. So making the api call from browser with: http://localhost:8088/api/?function=SetRateSlowMotion&Input=2&Value=0.5 works! But strangely using the same call in companion still does not work. So this does nothing:  I have tried without the "0" and changing to comma but it did not help. I use other cusom commands in companion which works so companion seems to connect as it should to vMix. So what am I doing wrong here?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
From the readme at https://bitfocus.io/connections/studiocoast-vmix : Quote:Using Custom Commands/shortcuts<br /> When using vMix shortcuts, please follow this syntax/layout, with space before the first value:
ReplayMarkInOut Value=5000
and if there is more than one parameter use "&" as a separator between them like this example:
SetOutput2 Value=Input&Input=3
 1 user thanked dmwkr for this useful post.
Originally Posted by: TL68  Thanks for input, Doggy! Got some progress when using input number. So making the api call from browser with:
works!
So what am I doing wrong here? Sounds like a Companion issue
Originally Posted by: dmwkr  From the readme at https://bitfocus.io/connections/studiocoast-vmix : Quote:Using Custom Commands/shortcuts<br /> When using vMix shortcuts, please follow this syntax/layout, with space before the first value:
SetOutput2 Value=Input&Input=3 Aaahhhh! Of course: a space before the first value!! As always the saying "The devil is in the details" is true. Now it works like a charm! Big thanks dmwkr!
Instant Replay
