Joined: 3/30/2023(UTC) Posts: 55 Location: Chicago Thanks: 8 times Was thanked: 2 time(s) in 1 post(s)
Is there a way via scripting to read UDP messages? Basically I'd want to cut to a specific input on receiving a UDP message and then switch to another on receiving another UDP message.
The reason for this is the system generating the commands can't do HTTP or TCP, just UDP. However, we can format those UDP messages as we like.
I'd been searching and can't find any information on this concept.
Thanks in advance.
Fritz Golman iHeartMedia
Joined: 2/23/2023(UTC) Posts: 23 Thanks: 4 times Was thanked: 10 time(s) in 3 post(s)
There is nothing built into vMix that supports this. However, a custom application could be written that proxies incoming UDP messages and then sends HTTP (or raw TCP) messages on to vMix.
Feel free to send me a private message, as I am available to hire if you would like this program written!
Joined: 12/27/2012(UTC) Posts: 5,089 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: ryxyz There is nothing built into vMix that supports this. Tried "System.Net.Sockets.UdpClient" instead of the usual Imports System.Net.Sockets?
Originally Posted by: ryxyz There is nothing built into vMix that supports this. a working try vMixUDP.jpg (59kb) downloaded 7 time(s).
Impressive!
This may just do the trick.
Now to set some actions!
Thanks!
Fritz
OK this has been working great!
One further question, I set up an action that is trapped to shut down the script. All is well BUT it needs to close the UDP connection so it's free for the next time it's run (otherwise port stays open and throws an error). No matter what I've tried I've not been able to get the UDP connection to close. Would anyone have the script commands to do this?
Thanks!
Never mind, figured it out.
receivingudpclient.close()
